Is the NSS wire absolutely necessary
Buttoning up some loose ends and was wondering if this wire is necessary for the engine to run. Motor/computer are 2004 LQ9 dbw, trans is a 2005 4L80, harness is a BP Automotive Premium harness, and the truck is an '86. The switch on the bottom of the column only has the plug for the back up lights. The truck was originally a 3 speed on the column, so I believe it had a switch on the clutch pedal that only allowed it to start if the pedal was pressed down.
Re: Is the NSS wire absolutely necessary
I don't have an NSS at all. I think my shifter has one, but I never bothered to hook it up (but I'm on auto). On a manual, its a good idea just for idiot proofing...but its not physically required for the truck to start (boats don't have NSS for example)
Ever seen somebody reach in the window and start their car while its in gear? I have, and its not pretty...... That said,, some columns have a physical lock out in any gear but neural and park, meaning they wont turn to the crank position in drive, I was thinking an 86 would be that way.See if it will turn in gear, if not you shouldnt need it.
Thanks guys, I'll check it when I get home this evening.
