-   -   Wheel studs (https://67-72chevytrucks.com/vboard/showthread.php?t=674246)
D-rock1981 06-18-2015 11:03 PM
Wheel studs
Got some new rims for the 68. Problem is the factory studs are too short. They come just to the end of the rim. Just curious if someone might have a part number for some studs that are longer? I'm guessing 1/2" longer should be enough. I can get about 2 threads on the front started and there just a hair to short to start threads on the back.
kwmech 06-19-2015 01:33 AM
Re: Wheel studs
Assuming you have a 1/2 ton 6 lug. Look at a dorman 610-259 which is 1/4'' longer or a dorman 610-157 which is 5/8'' longer
D-rock1981 06-19-2015 02:16 AM
Re: Wheel studs
Thanks. But now that I have think about it, I bet i may just need stepped lug nuts like the old school craigers use. I will investigate further tomorrow.
