-   The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=12)
-   -   1988 Chevy truck flares (https://67-72chevytrucks.com/vboard/showthread.php?t=674525)
nasblu 06-22-2015 10:58 AM
Is there anyone that makes the exact flares with same mounting as the factory for a 1988 chevy 2500/3500 trucks. The flares appear to have a gloss black metallic finish to them? All the aftermarket flares that I have seen have the flat finish. Were the flares painted from the factory on the models above the base work truck. I would like to get away from painting them if I can they will just get all chipped up but also dont like the flat black plastic look either. Can you get the original style flares through gm yet?
TennesseeZ 06-24-2015 04:51 AM
Re: 1988 Chevy truck flares
Have your painter mix in a flex additive when he matches the color, standard procedure for painting plastic
deejaaa1 06-26-2015 11:58 AM
I had a set of tape on flares on the 96. lasted a few years until the tape decided to stop holding. they looked OK but not OEM. they were also flat but left 'em that way. removed and sold 'em.
