-   WIW (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=83)
-   -   GMC 3/4 frame (https://67-72chevytrucks.com/vboard/showthread.php?t=678266)
Steven R 08-01-2015 10:46 PM
GMC 3/4 frame
4 Attachment(s)
I have a GMC 1972 2500 3/4 ton frame with V8 motor mounts. not sure if they are small block or big block mounts
It is straight and has no signs of any accidents or repairs, it a spring type suspension with over load leaf springs. I have removed the trans crossmember for personal use. being a 72 it has front disk brakes that look very useable but the rear brakes are toast. the frame is bare and has no wheels. the trailing arms have a bottom pcs of metal that needs to be removed and replaced. The rear end is a dana 60 with 4.10:1 gears
thoughts
I wanted to ask before I over price it in the for sell area. As per the rules and other members requests just looking on what it might be worth. thanks
Steven Rempel
68bowtie 08-05-2015 12:53 AM
Re: GMC 3/4 frame
as-is probably a couple hundred bucks.
if you part it out, $30 for the engine stands if sbc, $100 if bbc, $100 for the trailing arms, $150 for the rear diff, $75 for the front cross member.
just my $.02
Steven R 08-06-2015 07:01 PM
Re: GMC 3/4 frame
thanks for the tips
dubds10 08-13-2015 10:57 AM
Re: GMC 3/4 frame
$100 is avg for complete frames like that. Price is down cuz of scrap lol Used to sell for $200 regularily but now it's maybe $30 in scrape and non desireable to most & it's not 100% complete. Usually bring more parting them out if you can hold on to it for a bit. Or just start building a scrap pile.
Steven R 08-15-2015 07:17 PM
Re: GMC 3/4 frame
thanks guys I will have to think about this path I got my self in.
