-   -   1963 manual idler arm bracket differences (https://67-72chevytrucks.com/vboard/showthread.php?t=678537)
canadian_diesel1964 08-04-2015 03:53 PM
Hey all...hope your enjoying your summer..I got me an old school k14 moog idler arm for my manual steer 63. The old idler had a straight bracket and the new one has this curved bracket...did I put it on backwards? There was a spacer provided on the back side of the old idler ...not sure on this one...thx!
canadian_diesel1964 08-04-2015 03:54 PM
Re: 1963 manual idler arm bracket differences
New one here ...
1963c-10 08-04-2015 04:53 PM
2 Attachment(s)
My moog replacement is straight. I'll have to look at which part # I used.
frankslagoon 08-04-2015 10:03 PM
63 SB I remember scratchen my head too. this how it ended up. works good.
Lugnutz65 08-04-2015 11:47 PM
The picture below is not the best, but I know it is correct. The idler arm with a bend in it should have the spacer between the frame and the lower hole. So your photo shows that you have it twisted 180 degrees.
frankslagoon 08-05-2015 05:01 AM
Originally Posted by lugnutz65 (Post 7264127)
the picture below is not the best, but i know it is correct. The idler arm with a bend in it should have the spacer between the frame and the lower hole. So your photo shows that you have it twisted 180 degrees.
x2
canadian_diesel1964 08-05-2015 02:56 PM
Thanx guys ...it came to me last night....got re done as your can see.....
