Matching Torsion Spring Height Help
Can anyone with more experience than me please tell me if there is a way to make sure that the driver and passenger side torsion bars are adjusted to the same height? Can i just count the bolt threads? Should I take the bolts all the way out and tighten again counting the revolutions? Any help would be appreciated.
Re: Matching Torsion Spring Height Help
When I lowered my 60 I jacked it up and counted the same amount of turns on one side then did then turned on the other side to match. Make sure to soak the bolts with PB blaster before
