-   -   8 lug rear disc conversion? (https://67-72chevytrucks.com/vboard/showthread.php?t=679570)
Ram-Man 08-16-2015 03:22 PM
Looks like I have the answer to swapping axle shafts isnt going to be easy. Is there a 8 lug rear disc conversion out there?
racerop 08-16-2015 03:47 PM
Re: 8 lug rear disc conversion?
lugnut4x4.com has conversions for eaton and gm corporate 14 bolt
Redline novdog 08-16-2015 04:46 PM
I have a 14bolt U can get 6lug hubs for I think the bolt pattern I need,but /hub o.d. will not allow that internal diameter.(5x5.5???)Help needed.
Ram-Man 08-16-2015 05:12 PM
I was thinking converting it to a 5 lug all around but now reconsidering and leaving the 8 lug because there are alot of wheel options out there. Maybe I would be better off leaving it 8 lug and just rebuilding the drums that are on it in the rear.
Redline novdog 08-16-2015 05:34 PM
The 6 lug wheel options are very good also. the offset is what you have to look at.Something to think about (The 14 bolt is almost bullet proof)
