-   -   CLR Treatment for surface rust question (https://67-72chevytrucks.com/vboard/showthread.php?t=679928)
68Stepper 08-20-2015 01:32 PM
Quick question on the CLR process.
Do I need to neutralize the CLR afterwards with a base such as baking soda? There are several posts about the CLR thing but this was never answered.
After I've given my truck the CLR bath with green scotch brite pads, do I keep the whole truck wet just as if I was washing a normal car? Or are you supposed to immeditately dry each treated panel after the CLR is scrubbed and rinsed with water? I saw on a thread that rust would immediately form if you didn't dry it completely immediately after the treatment.
Please clarify,
LockDoc 08-20-2015 06:17 PM
Re: CLR Treatment for surface rust question
Please clarify,
The baking soda would neutralize any acid present. I would do one area at a time and rinse it good with cold water. It wouldn't hurt to dry it as you go but you will probably get it wet again when you do adjacent areas....
LockDoc
kingsolver72 08-20-2015 06:33 PM
I don't think I'd put baking soda on it. Just wash and let it dry.
I definitely wouldn't apply baking soda if it were to be painted.
special-K 08-20-2015 09:06 PM
Hosing it off dilutes the acid just fine. It's a weak solution to begin with. I've never done anything but scrub and rinse. If you are still concerned, just go ahead and give it a normal wash
Tim Christian 08-20-2015 09:20 PM
Wear gloves
Already Gone 08-20-2015 10:17 PM
I did a piece on the box side on atruck I had . I just used the CLR and dint even rinse it. I did it in Sept/Oct and the truck sat outside all Winter and no rust came back by spring. If I was doing lots on a truck I'd be rinsing after.
68Stepper 08-21-2015 10:19 AM
Sounds good, I appreciate the help. Thanks for the info!!
