4L80E pan hangs below frame
so im running all cpp stands/mounts/sliders/trans member and i peeked under the truck to see the trans pan hanging about an inch below the frame. :confused:
options cuz she wont lay frame with that..... |
Re: 4L80E pan hangs below frame
Sorry.... 69
What is your trans angle at? You might be able to lift the trans a bit to get more clearance.
:wop:
you need pix of the pan hanging lower than the frame? lol i'll snap some tonight and get a rough measurement.
havent checked angles yet, but i need to soon so i can get my driveshaft shortened once my new spicer slip yoke comes in. im running all cpp stuff with the ES poly mounts....i guess i could call them and see if they might know roughly how the drivetrain sits. i do know....that if i have to raise the trans some....it'll be time for a high hump cuz i had to flatten the lip out to make the trans clear with how far back it is now. btw, hart_rod.....havent scanned enough to find a legit answer but suggestions on where to run the dbw pedal harness thru the firewall once your bracket is bolted in...which looks noice btw.... |
I used a aftermarket tubular cross member and had to use about a 2.5" spacer to get my drive line angle correct.
So don't get too upset until you get your angle set. I remember looking at my pan thinking "there is no way this is going to work like this" |
oh im not upset. just something i noticed that would need to be addressed after i got the LS running....since dropmember and bags are the next step lol
| All times are GMT -4. The time now is 08:16 AM. |
