Camaro exhaust manifolds collector connection
I am not sure of a good source of the exhaust collectors for the ls3 exhaust manifolds for the downstream section of my exhaust. I have a donor suburban that I am using for my swap and was planning on using the collector parts from it but the suburban is a 3 bolt flange and the camaro a 2 bolt.
Without looking at the suburban stock exhaust, can I use the exhaust piping socket and get a pair of 2 bolt flanges off of ebay like the one in the link? http://www.ebay.com/itm/Universal-FL...3d441d&vxp=mtr Does anyone have a good source for a brand new pieces instead of me hacking one off of the old midpipe as I butchered it really good getting the engine free from the truck. Part numbers from Oreillys? |
Re: Camaro exhaust manifolds collector connection
You can buy laser cut exhaust flanges for the Camaro manifolds from ebay.
I bought the correct flanges for my manifolds and then cut up the y-pipe from my parts truck to make adapter pipes to connect my existing exhaust. Came out pretty good. |
So like the one in the link or are there a different flange out there for the camaro exhaust?
Like this :
http://www.ebay.com/itm/LS3-5th-gene...749dcb&vxp=mtr The universal one may work, but you'd be on your own there. |
Great info!
Here's a link to a stainless version that uses the stock gasket.
http://www.ebay.com/itm/Fabberge-201...421e9e&vxp=mtr Here's a link to a mild steel version that also uses the stock gasket. http://www.ebay.com/itm/CHEVY-CAMARO...3d2f32&vxp=mtr Same manufacturer as above but in stainless. http://www.ebay.com/itm/CHEVY-CAMARO...b4e715&vxp=mtr |
Your local or my local muffler shop had the flanges for $3.50 each and welded 4"length pipe to the flanges all said and done for $22.00. The gasket at Chevrolet dealership $3.95ea. Running Ls3 manifolds on my suburban also
| All times are GMT -4. The time now is 06:39 AM. |
