-   Engine & Drivetrain (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=24)
-   -   Another axle question or two (https://67-72chevytrucks.com/vboard/showthread.php?t=685764)
vancelot69 10-19-2015 12:42 AM
Yesterday evening I noticed some petroleum on my inner tire. Is there a way to tell if it's the axle seal or brake wheel cylinder without taking it apart? If it turns out that it's the axle seal, am I correct thinking that I will have to remove the axle shaft to replace it, therefore I will have to take the C-clip out in the differential?
Thanks!
61K10 10-19-2015 01:38 PM
Re: Another axle question or two
Yes. pull the tire and brake drum and have a look.
kwmech 10-19-2015 08:57 PM
You could also inspect the master cyl reservoir to see if it's empty
nonstop 10-19-2015 09:13 PM
Run your finger trough it and smell it. Both are distinct smells and texture.
crazy longhorn 10-20-2015 12:40 AM
Just like I taught my sons...."run your fingers through it" then smell it;) I hope the mods have a little "humor" this nite? All jokes out, yes the gear lube does have a very "skunk" odor. the brake fluid , has a stinky /sweet smell. Longhorn
