Changing Booster and MC
2 Attachment(s)
OK, Here is the question...................First the build up to the question. I have a 1979 Blazer frame, complete rolling chassie, Brakes, shocks, everything except the body. I am going to use the chassie to put a 1987 Cab on it and make a truck out of it. I am now starting to put things back together after about 8 years of off and on work on it. I picked up a lot of 87 parts over this time period. The one thing that I have a concern about is the Brake Booster came off a 1987 Suburban. THE QUESTION.....Drum roll please.........Will the 87 Suburban Booster and MC work my be using the 1979 Blazer Braking system? I going from this...Attachment 1458921 To This.....Attachment 1458923 . I want to use the Newer Style. Thanks For reading.
John |
Re: Changing Booster and MC
My understanding is no nothing is going to just bolt up. But if you don't mind doing some extra work it could possibly work.
Thanks enaberif, It seems to bolt up to the firewall. Everything looks like it matches up. I am just wondering if it will work,like stopping the truck:haha::haha: John
I would say it should work.
I used an 85 c10 MC and booster on my 80 c10. The brake lines going from the MC to the Proportioning valve were different. I had to use the ones from the 85 since the ones from my 80 wouldn't line up correctly on the MC. Everything works great with no issues. |
I just swapped to a later model master cylinder on my 73
The hole in the firewall was a bit smaller, used a hole saw and some tubing to open it up. |
Sounds good so far 69heavychevy , KQQL IT....you said the hole in the firewall was a bit smaller, maybe that is why the plastic tube does not go into the firewall to well. I'll have to make the adjustment then. Thanks Again. John
The vacuum booster could be the same, I swapped from power to manual using an 84 manual brake master cylinder.
And had to open up the hole a bit. |
Also make sure the brake pedal hole is proper - may need to be lower or higher?
A pedal for non boosted vs boosted the hole is lower for the rod. |
My 73 was in the top hole, with the booster. Stopped great with 9" vacuum.
