-   -   Swap non a/c wiring harness for factory a/c harness? (https://67-72chevytrucks.com/vboard/showthread.php?t=688223)
NotaBronco 11-11-2015 02:13 AM
I have a non a/c dash wiring harness but my truck is a factory a/c. Can I simply swap out this harness (pictured) for an a/c harness? If so, does anybody know where I can buy one, or maybe have one you'd be willing to sell me? Thank you!
MARKDTN 11-11-2015 08:44 AM
Re: Swap non a/c wiring harness for factory a/c harness?
It's been a while, but I converted a non-A/C truck to A/C. I am pretty sure that all the wiring was add-on and not incorporated into the main harness.
WIDESIDE72 11-11-2015 12:51 PM
You can swap the non AC harness for non AC harness and vice versa. I have done both. I had a decent AC harness from a truck I parted a while back. It will be this weekend before I can check if I still have it.
NotaBronco 11-11-2015 10:27 PM
That would be great wide-side. Thanks!
WIDESIDE72 11-17-2015 11:55 PM
Here are some photos finally. It has a couple of flaws, which I included in the photos. One is the red wire that plugs into the fuse panel. IIRC this piggybacks the radio or cigarette lighter power. One wire was burned in two. The other is a brown or black wire. It was cut. It has been so long ago that I pulled this harness that I forget what it goes to. I will see if I can find my manual and wiring diagram to help identify it. $40 shipped, you cover PayPal fees or money order is OK as well.
WIDESIDE72 11-17-2015 11:56 PM
This site won't let me download my photos for some reason. PM me your email address and I will send them directly to you.
NotaBronco 11-19-2015 02:45 PM
I'll take it. PayPal info?
