-   -   Wilwood Master part number? (https://67-72chevytrucks.com/vboard/showthread.php?t=689260)
aod92 11-21-2015 08:02 PM
I've been looking at the billet wilwood master cylinders. Disc in front drum in the back. Not sure which one I should use. Any of you guys have a part number for the correct one?
lolife99 11-21-2015 08:51 PM
Re: Wilwood Master part number?
Look on Jegs or wilwoods website.
There are three different finishes, ( aluminum, polished and black), and three different bore sizes, (7/8", 1", and 1-1/8" bore).
aod92 11-21-2015 08:52 PM
What's the best way to figure the bore size I need?
bgood70 11-23-2015 12:52 PM
Give WilWood a call. They will ask some questions like, line size your running, whether you are running disk brakes, you want to use manual or a power booster etc. I am running 1" bore with no booster and I like the feel and I have good stopping power.
lolife99 11-23-2015 12:55 PM
I think most run a 1-1/8" bore with a booster.
I like the 1" bore for manual disc brakes.
I agree, give Wilwood a call.
