Heater blower motor resistor question
My fan only works in the high position, so I was told it had to be the resistor. I took it out and it was corroded badly but not broken so I cleaned it up and checked continuity. It tested good between all poles so I put it back in. Still no joy. Then looking at the plug I noticed I'm missing a wire. What goes here - ground maybe? There is a corresponding pole on the resistor but I don't have a wire in that spot.
Re: Heater blower motor resistor question
my 79 has other colours
This is on my CUCV, so that may account for the color differences. You have the heavy duty resistor too, and have a wire in that spot of the plug. Looking at the back-side of the resistor, I don't see how it can work without one, but I posted the same pic and question on Steel Soldiers and another guy said his didn't have a wire there either. Thanks John. I'm going to try a new resistor and see if that fixes it.
Mine doesn't work on the lowest setting. I will follow along.
just thinking some fans are wired to be on low all the time,no off
I cut the brown wire at the speed switch,in both the 78 (fan 3 speed) and 79(fan 4 speed), to have low as an "off", maybe someone else had another idea to stop the fan?...pull out the wire? |
You really need to download the DOD CUCV TMs from Steel Soldiers and the GM CUCV parts and illustration catalog. http://www.steelsoldiers.com/....CUCV-TMs 52D_1984_87_CUCV_Parts_and_Illustration_Catalog.pdf Double Orange wire is from HI switch and out to the fan. This one works. Yellow is low. Light Blue is Medium. This is Orange with a stripe faded to pink in your picture... Are you getting 12v on the yellow wire with the fan on Low and the Ignition switched on? Move the switch to Medium and check the LT Blue wire. No volts= bad fan switch or wire. Volts=bad resistor. The CUCV GM parts book is in the manuals link or you can use the DOD parts manual TM92320-289-20P The CUCV resistor is GM # 500890 http://johnnynightstick.s3.amazonaws...S/CUCV_HTR.jpg |
Thank you sir. I'll check those for voltage. I have those manuals and had looked but could not find it. I was looking in the -20, I'm not sure if I have the -20P.
TM9-2320-289-20P is the UNIT MAINTENANCE REPAIR PARTS AND SPECIAL TOOLS LISTS (parts book) TM9-2320-289-20 is the UNIT MAINTENANCE MANUAL (Service Manual) I got the wiring diagram from this one. Understanding Army Manual Numbers |
I'm only getting current to double orange, or high. I've started a gauge project to replace the idiot lights and had planned to have the cluster out later this week. I'll check the switch then. Someone on steel soldiers said the switch plug was bad about overheating and melting. I looked up under the dash at it, looked good from what I could see. I'll get a better look after Thanksgiving. Thanks for the help.
It turned out the switch was melted at the plug. I bought one of the replacements from LMC. Question: What is the correct way to release the cables from the selector, where they snap in? It looks like a small flathead screwdriver inserted next to the cable would release the clip. Just want to make sure, the new one wasn't cheap and that tab doesn't give much.
I've had similar problems on multiple cars. The first time I encountered this problem, yes, it was the resistor pack. However, on my current squarebody the symptoms were the exact same but the problem was the contacts within the blower switch.
I was able to take the switch apart and clean the contacts, but with little clips and tiny springs, it's not a task for those with a faint heart (or poor eyesight :lol: ) Exact same symptoms, different problem. Just another reference for people searching this thread in the future. |
Well, I got the LMC heater controls hooked up. The temp and vent controls don't feel so good with a cable hooked to them. Flimsy. Does not feel like it will last. That's speculation though, and I won't ever know. It's going back. The fan switch is bad out of the box. I hooked up the old one to be sure. Oh well. It's not like the post office is crowded this week. Fudge.
Good info. I was thinking about trying the LMC repop, but if it feels flimsy, I think I'll just stick with reconditioned original.
My symptom was intermittent no power at the fan switch for several years of fiddling with it. I finally got an LMC heater control assembly and it still did not fix the problem. I could wiggle the connector at the fan switch and it would work. The solution was to get a new short harness and connector to the heater control. I think you can find this harness in the AC Delco pigtail/harness catalog online. You might also find an AC Delco heater control online from the OEM suppliers - most likely cheaper than LMC.
When I was in college I worked for one summer in the Chevy parts plant that made these heater controls. One guy had a full time job fixing these things so the heater control levers would work - if they worked smoothly coming off the assembly line it was an exception. These were far from precision made components. |
Yeah, apparently they get hot inside the pigtail and melt at the connection and you can still buy the pigtail or the switch separately. I haven't been able to find the whole assembly anywhere but LMC. Out of the box, it seemed nice. The levers moved smoothly with positive detents. But once a little bit of tension was on them, they were crap. And I made sure not to hook those cables up in a twist, they were just like they came off. Oh well. I'll see if someone here has one. If you know of a supplier for AC Delco replacements I'd appreciate it.
I couldn't find a replacement here, so last night I found a decent looking set of factory controls on ebay and bought them. Then I drove the truck this morning and the LMC fan started working. The lower slider controls the temp of the air, that one moves OK. But the upper control selects between OFF HEAT and DEF, that one is hokey as hell. Hopefully the OEM controls I bought show up and look as good in person as in the pics so I can swap them out and have that working again.
If the switch is melting... You can use a 5 terminal 40A Mini ISO relay to limit the current through the switch when the blower is set on HI. The civilian AC equipped trucks did that with a proprietary relay.
Terminals; Coil- 85- Chassis ground. Coil+ 86- Orange 52A wire from switch HI COM 30- Power Out to Blower NC 87a-Orange 52B from resistor pack (Low & Med) NO 87- 12v battery power through a fusible link (HI) |
Autoshop101 Relays |
Terminals; Coil- 85- Chassis ground. Coil+ 86- Orange 52A wire from switch HI COM 30- Power Out to Blower NC 87a-Orange 52B from resistor pack (Low & Med) NO 87- 12v battery power through a fusible link (HI) it's starting to make sense. I think. Except for NO 87- 12v battery power through a fusible link (HI). Is that a wire you need to add, or can that come from the switched hot on the back of the fan speed plug? Whichever one that is, I'm not sure. |
4 Attachment(s)
I should have skipped the whole LMC controls and gone this route from the start. The cables clip onto the little control board behind the switch. I couldn't get mine to release, so I forced the issue and tore the tab. Why fight it, right? I have a new one sitting here from LMC. So now, instead of just getting a new switch for my old controls, I need another complete unit. Ebay to the rescue. These are the sellers pics.
4 Attachment(s)
I took it partially apart so I could polish the face plate and clean the dirt behind it as well. But all I really did was soak it in the kitchen sink in hot water and Dawn for about 20 minutes then clean it with a little brush. Blow dry with compressed air, WD40 the switch, blow that through the switch with compressed air, repeat twice more to be sure, then put it back together. The sliding parts got a fresh shot of white lithium grease The knobs pull straight off and the face plate is held on by a little tab at the bottom center. Just posting these up to show its easy and there's no need at all to waste money on the LMC (chinese?) version. The switch (orange part) is held on with two small screws and can be replaced if needed. Keep the rest.
