-   -   Broke one of the accelerator pedal pivot studs off in my 67 (https://67-72chevytrucks.com/vboard/showthread.php?t=690519)
72farmer 12-04-2015 08:22 AM
I am trying to go back to the original pedal.One of the studs is broken off in threaded part on floor pan.Can I get under truck and remove threaded boss and weld another one on from underneath?
67 chevelle 12-04-2015 08:29 AM
Re: Broke one of the accelerator pedal pivot studs off in my 67
yes they go through , you may be able to grab the end and unscrew it , unless its rusted solid
chanclas90063 12-04-2015 12:29 PM
I just replaced the gas pedal on my 1970 C-10, and I found the pivot studs at The Truck store in the OC. They are just a couple of dollars.. Good luck
kehstr 12-04-2015 01:45 PM
a left handed drill bit usually works really well to remove those sorts of things, unless they are rusted solid. The problem is finding them, not everywhere has them
davepl 12-04-2015 03:43 PM
The guy with spares always lives on the other coast!
You might also be able to tack a nut onto whatever remains - I even got a rusted seat belt bolt out that once, and I didn't think there was any hope. I think the heat actually does a lot of it.
It's also -possible- that some is poking out the underside. You could tack a nut onto that, or maybe there's enough to grab with vice grips (doubt it, threads aren't that long).
Worst case would be what I think you're saying, knock it off entirely and tack a nut on there as a new receiver, but that'll work too.
Gromit 12-04-2015 10:54 PM
For some trucks (mine) I think it should be a maintenance procedure to put a drop of oil or anti-rust on each side of the threads of these accelerator pedal posts once a year.. such a PITA if they go wrong and it only takes a minute...
NC_John 12-05-2015 06:47 PM
I broke mine. Drilled it out, recapped it and put in a repop. Then I got smart and converted over to cable throttle.
