285 70 15 BF Goodrich silvertown tires
Looking to upgrade to a taller rear tire. Any one running this size tire that can throw up a pic and tell me there back spacing on there wheel. Thanks in advance.
Re: 285 70 15 BF Goodrich silvertown tires
Any 8 or 8.5 standard offset wheel would work. I also had 10" with narrow housing and same tires with 7" drop on both trucks.
8.5 wheel with stock 5 lug rear.
10" with 67-69 housing and standard offset
Mind giving the specs on the orange truck ... tire and wheel size front and rear. Also what drop do you have and how did you do it?
Excellent proportions on that ride. Id like to stick the picture with the info in my 67-72 truck folder ... thanks! |
Orange truck at the time had 8.5 wheels on all 4 corners, but now has 7" on front(tires hit inner fender). Front drop is ece 2.5 spindle/2" spring. Rear is ece 6" spring/1" block. Can't really tell by looking with 7" on front but lot safer driving. 285/70/15 rear tire. 235/70/15 front tire. Wheels are American torque thrust d.
The best look for these trucks!
275/60R15 on 15x8 w/ 3.8" BS rear wheel.
Wheels: TTII 15x8 w/3.8BS rear, 15x7 w/3.78BS front. Tires: BFG 275/60R15 Rear, BFG 235/70R15 Front (Both 28" tall) I went with 275/60 in rear because 295/50 are not readily available. Went with 235/70 in the front to give me additional LCA ground clearance. |
:) ttt
2 Attachment(s)
They are on now and fit great. 285 70 15 rear 255 70 15 front
Looks good. I like that size tire.
I don't have any pictures to share, but my 69 SWB stepside has 285/70/15 rear and 235/70/15 front. tires are mounted on stock 73-87 style 6 lug G.M. wheels with dog dish hubcaps. front suspension has 1.5 coils cut off the stock springs. rear has 6" drop springs with a 1" lowering block.
My truck is lowered approximately 5" in the front. This was accomplished by cutting 1.5 coils off the stock front coil springs.
Do the Silvertown treads match the BFGoodrich pattern?
Where are you guys buying these 285's? I have seen them on Cokers web site, are they the only distributor?
summit racing sells them
