-   -   sending unit solution (https://67-72chevytrucks.com/vboard/showthread.php?t=693831)
weldvair@embarqmail. 01-05-2016 10:23 PM
I bought dolphin gauges where the gas tank sending unit is 90 ohms instead of the 30 ohms used in a 1968 c10.
I am looking for a solution that does not require welding on the tank.
Has anyone removed the movable float part of the new sending unit & attached it to the 1968 sending unit thus keeping the original gas tube...
if so how did you do it
VetteVet 01-05-2016 11:14 PM
Re: sending unit solution
Do you have your ohms backwards because the 68 C10 has a 90 ohm sending unit.
GMCPaul 01-06-2016 05:15 AM
^^x2^^
VetteVet is 100% correct the 67up trucks use a 0-90ohm fuel sender, the 1966 and earlier trucks use a 0-30 ohm fuel sending unit.
Paul @ GMCPauls
weldvair@embarqmail. 01-07-2016 12:45 AM
thanks for clearing that up.....don
