-   -   radiator hoses LS swap (https://67-72chevytrucks.com/vboard/showthread.php?t=695289)
PowerdbyChevy79 01-20-2016 01:14 PM
whats up guys... starting the mock up of the LS in the 67 what hoses are yall using for the swap...
michael bustamante 01-20-2016 01:24 PM
Re: radiator hoses LS swap
im doing the same thing in my 67 too. from what ive seen, most guys are using the same upper rad hose as the doner veh. .
or you can drop some $$$ and get a cust radiator with the top inlet on the passenger side
PowerdbyChevy79 01-20-2016 01:28 PM
ya I have a ron davis radiator.. the top inlet is on the pass side.... just trying get an idea what hoses to grab.. this a crate LS3 so no donor hoses..im going to make a template today go hunting..
brad_man_72 01-20-2016 01:29 PM
It depends on what water pump setup and radiator you are using.
5.3 truck engine/water pump with stock 67-72 radiator - 01 v8 silverado upper and part of my old upper for the lower.
Aruba1 01-20-2016 01:36 PM
I got an "LSX" radiator with passenger side inlet and outlet. I made a upper and lower radiator hoses out of the upper radiator hose.
PowerdbyChevy79 01-20-2016 01:39 PM
What hose did you use... do you have a part#
Aruba1 01-20-2016 01:41 PM
Probably I got a 2001 Suburban 1500 suburban hose or something similar.
