-   The 1947 - 1959 Chevrolet & GMC Pickups Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=13)
-   -   Ad running boards on S10 frame (https://67-72chevytrucks.com/vboard/showthread.php?t=695438)
fredscarryall 01-21-2016 11:06 PM
Anyone have pictures of setting up the running board brackets on a S10 frame. I need some good ideas.
albodz 01-22-2016 11:37 AM
Re: Ad running boards on S10 frame
I made mine from 1"/2" tubing. I drilled and tapped plates for the running boards and welded the plates on the running boards. So they bolt to the running boards and bolt to the frame. Easily removable. Took some time fitting but I'm happy the way they turned out.
Clay54 01-22-2016 02:08 PM
Fred, there are several builds on this site that show how they did the running board brackets. Check the S10 swap how to post #78 (first link below) and then check post #17 on the second link. The brackets in the 1st link are "homemade" and the ones in the second link are the stock brackets cut down to fit the S10 frame. There are many others but most use the same principle as these two. Clay
http://67-72chevytrucks.com/vboard/s...d.php?t=632686
http://www.killbillet.com/showthread...-step%29/page2
chopit 01-25-2016 03:27 PM
Here is what I have...bolts to frame
HUSSEY 01-28-2016 05:58 PM
I've been needing to get back out to the garage and work on my truck some. Running are next on my list. I really like this idea, I think it would a quick way to get them installed and lined up. Thanks for posing!
HUSSEY 02-18-2016 12:21 PM
So I stole chopit's design. Then I saw how fredscarryall did his in his build, which was much easier.
The only advantage for me in the the way I did it, I think, is that it made it easy to get the boards lined up. My boards were warped like hell. They had been patched by the previous owner, which I think contributed to the warping. The bracket I made up straightened them out.
https://lh3.googleusercontent.com/-G...217_174832.jpg
chopit 02-18-2016 08:35 PM
Very nice! Always room to expand on previous ideas!
mr48chev 02-18-2016 09:20 PM
That's how it's done. Take a good idea and run with it.
HUSSEY 02-18-2016 10:04 PM
It definitely worked out well...couple more pics.
I learned that if you keep the bar parallel to the outside of the running board, then your two mounts can be of the same length...this ended up working out by dumb luck for me. My forward mount is mounted just behind the splice on the frame, nice flat spot. The rearward mount is forward of the rear of the cab.
You can see I had to clamp the running boards down to my welding bench because they were warped so bad.
https://lh3.googleusercontent.com/-h...217%252529.jpg
https://lh3.googleusercontent.com/-_...218%252529.jpg
https://lh3.googleusercontent.com/-W...219%252529.jpg
https://lh3.googleusercontent.com/-e...220%252529.jpg
https://lh3.googleusercontent.com/-3...221%252529.jpg
https://lh3.googleusercontent.com/-x...222%252529.jpg
https://lh3.googleusercontent.com/-v...223%252529.jpg
https://lh3.googleusercontent.com/-v...224%252529.jpg
https://lh3.googleusercontent.com/-9...225%252529.jpg
joedoh 02-18-2016 10:56 PM
amazing work!
