-   The 1947 - 1959 Chevrolet & GMC Pickups Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=13)
-   -   55 2nd series hood latching (https://67-72chevytrucks.com/vboard/showthread.php?t=696357)
mygirlz55 01-30-2016 03:46 PM
My 55 2nd series hood isn't latching when I close the hood. It catches in the slightly open position, but when the hood is closed completely, it doesn't latch. Is there something I'm missing in the latch that holds it shut when closed?
Daze57 01-30-2016 08:42 PM
Re: 55 2nd series hood latching
there should be 2 springs on the latch the small spring usually are missing - look at the latch -u should be able to see where a small spring hooks on.
see if that helps. i dont have a picture of one offhand --maybe someone will chime in and have one.
Miller197 01-30-2016 09:45 PM
2 Attachment(s)
Hey mate,
As daze said it could be that one of the spring are missing as its held shut by being spring loaded. Heres a couple pics of the latch out of my 55.
In the end i decided to do away with the original latch and put in a different catch from the wreckers with a positive lock
Hope the pics help
mygirlz55 01-31-2016 02:09 AM
Originally Posted by Miller197 (Post 7467605)
Hey mate,
Hope t3e pics help
Yep the picture helped. Missing spring and the spiral spring is broken off too. Thought the spiral spring was just a piece of metal holding parts in place.
Couldn't find a picture of the back side or the springs online.
Now I've found a spring kit... but only for a 55 car hood latch. Anyone know if these will fit the truck latch?
Miller197 02-03-2016 06:14 AM
Im fairly sure their the same.
Looking at that photo of the spring kit it looks like the right stuff
Daze57 02-03-2016 01:19 PM
good picts Miller197 !!
It sure does look like the same springs - make sure they fit tight so they dont fall off and give the latch a good shot of wd40 or a good white lithium grease to keep it from binding up . glad it all worked out !
