Torque Converter lockup wiring question.
I'm in the middle of my LQ4/4L80E swap, and my instructions that come with my standalone harness states in needs 12 volts input from my brake pedal.
does this mean 12v when the pedal is pressed in or 12v when my foot is off the pedal? I know older cars (including my 87 Suburban) are 12v when your foot is off the pedal and goes to no volts when the peal is pressed in. |
Re: Torque Converter lockup wiring question.
It depends on which pcm you are using for early and late engines. Early ls1 style (24x) engines need 12 volts removed with brakes applued. Later e38 (58x) ecu need 12 volts applied with the brakes applied.
My motor/PCM is from a 2004. so I need zero volts when my foot is off the pedal, 12v when I'm pressing the brakes right?
Nope. Use a 4 pin gm switch from a 1990's s10. Two terminals for brake lights. Connect other terminal to switched ignition. Last terminal to purple tcc wire on pcm.
My existing brake switch has connectors for cruise control that I won't need, could I use those, or would you recommend getting one from an S-10? |
For what it's worth, this is what mine currently has.
