Walbro 255 Bundy fittings same as GM?
I've ordered a Walbro 255 external pump that comes with the Bundy fittings. Do these fittings match up with GM 3/8" quick connects like the factory lines?
Re: Walbro 255 Bundy fittings same as GM?
All my pushlock fittings were the same size..from fuel rail to pump.. but I believe the gm ones are listed as metric..but 3/8" is basically the same as 10mm..
