Will a 4L80 fit in a low hump tunnel?
Quick question, will a 4l80 fit under a low hump cab? If so did you have to use the slider motor mounts? Thanks in advance. JC
Re: Will a 4L80 fit in a low hump tunnel?
Yes, no problem. I have a 4L80E in my truck, used slider mounts and modified the stock crossmember.
yes. but that hump is FULL once it's in there ;)
Thank you for the help
