-   -   What is this piece called (https://67-72chevytrucks.com/vboard/showthread.php?t=704989)
craigg1 04-22-2016 05:14 PM
Fixing to order some new parts so I figured I would go ahead and replace this piece as well. Its circled in yellow, starting to look dry rotted, cant find it in my catalog and not sure what its called.
summitflier 04-22-2016 05:22 PM
Re: What is this piece called
Appears to be a weather seal between the cowl and hood.
http://www.1aauto.com/hood-to-cowl-w...FQ6naQodxmUDDg
rockridgemike 04-22-2016 05:24 PM
I got mine from lmc in with the door weather strip kit
cypressbog 04-22-2016 05:38 PM
I think it's the fire wall wire harness gutter. They come with the replacement engine wire harness like gmcpauls.com sells.
http://gmcpauls.com/wiring_harnesses.htm
leddzepp 04-22-2016 05:42 PM
Originally Posted by cypressbog (Post 7569825)
i think it's the fire wall wire harness gutter. They come with the replacement engine wire harness like gmcpauls.com sells.
x 2
craigg1 04-22-2016 05:46 PM
Thanks for the replys. After researching more, looks like it is called the firewall wire harness gutter. Truckandcarshop.com has the firewall and radiator support harness gutter as a pair.
hugger6933 04-22-2016 06:01 PM
Get your mind out of the gutter!!! I am so sick of seeing these trucks that are "assembled" or "Drive able" or even resemble a truck on any way. No man just kidding at least some get to have a truck that is a truck
hugger6933 04-22-2016 06:02 PM
i hope you know I don't have anything against you or your truck just trying to be funny
craigg1 04-22-2016 06:44 PM
No worries!
