TH350 vs TH400 Mounts
Do the TH350 and TH400 share the same transmission mount (rubber block at the crossmember)?
I'm replacing the transmission mount for my TH350, i have the mount bolted to the transmission, but I'm having a hard time getting the crossmember bolt holes to line up. Maybe I have the wrong mount? |
Re: TH350 vs TH400 Mounts
http://static.summitracing.com/globa...-9442_w_ml.jpg
This style is: Designed to work with Powerglide, TH-350, TH-400, 700R4, and all Borg-Warner, Muncie, Saginaw, Chrysler 4-speed, and Doug Nash 5-speed transmissions. |
I've seen that one a few times while googling this question. The mount I have only has two holes on the crossmember side instead of the three shown above (no hole in the middle). Maybe I just need to push the transmission until the holes line up... not an easy task when laying on my back underneath the truck!
If I still had the old transmission mount I could compare the two, but the old one literally disintegrated :rolleyes: |
They are the same. Don't worry about the 3rd hole for the TH350 and the TH400.
Put a 12" by 12" piece of study plywood (3/4" or so) and put it on your floor jack and then support the transmission by the pan. Let hydraulics do the work for you. Gary |
Also loosen up your crossmember and get all the bolts started before you tighten anything up.....
You may want to 'open' up the holes on the cross mount a little, just because if the rubber is under stress when it is all tightened up it will just wear out again really fast.... |
