17" dually wheel swap
I have a 1998 C&C dually rear end that I have converted to disc brakes. I was told that the calipers would hit on the 16" wheels and that a 17" dually wheel from '08 -'10 would need to be used to give clearance of the caliper. I checked bolt pattern and those seem to match up. I could not find any factual information on the hub centers of the 17" wheels. My current hub and 16" wheel is 4.56 hub center. I got a hold of a tire company rep and he said the 17" wheels have a 4.60 hub center diameter. Since these dually wheels are hubcentric, I'm .040" larger in diameter with the 17" wheels than the 16" wheels and this concerns me. I would like to stay with a stock wheel if possible, but right now I'm up for any resolution. Has anyone swapped out their '73 - '98 16" dually wheels for 17" wheels? Any advise or suggestions to getting to a 17" wheel all the way around the truck???
Thanks in advance for any help. |
Re: 17" dually wheel swap
I am curious about this set-up as well.
You'll need hub-centric rings to adapt the later model 17"s to the earlier model hubs. They take up the slack so the hub remains the pilot for the wheels vs the studs.
Can you tell us more about these centering rings? What they look like, where do you get them?
I was told the hub centers of the 17" wheels would need to be machined out at least 3/8 of an inch in order to allow the centering ring to have enough meat on it to hold up. Does this sound correct or is there an easier way?
| All times are GMT -4. The time now is 06:51 AM. |
