-   -   Looks like I'm pulling heads, again!! (https://67-72chevytrucks.com/vboard/showthread.php?t=71391)
swervin ervin 10-04-2003 05:54 PM
Well, about 10 months ago I get a wild hair to increase my compression a tad, about half a point. I read up on different gaskets I could use. After much ado, I decided to go with some Felpro, 1094 steel shim, .015" thickness. I have aluminum heads and talked to several different people who said they would be fine. You could feel the increase in power for sure.
Anyway, for the last couple months I noticed I was having to add water every once in a while. I checked everything and couldn't find any leaks. I figured something was amiss somewhere. No water in the oil or any leaks. I sort of put it by the way side.
Yesterday, I noticed something leaking at the back of the engine. I decided to change my oil today. While under the truck, I investigated the water problem to see if I could find where it may be going. I also wanted to see what the leak was I seen. Well, right above the oil filter, on the block, it was steam cleaned, down to the metal. Looks like the head gaskets are leaking at the drivers side back corner. So much for the steel shim gaskets.
I ordered a set of Felpro 1003 composition head gaskets and a set of Felpro 1256 intake gaskets from Summit.
It sure sucks having to pull the heads again. I'm going to loose the increase in compression, but it will gain me more reliabilty. But with my mindset right now, I can't stand the thoughts of pulling the heads off. Oh well, things could have been worse I guess.
old Rusty C10 10-04-2003 06:53 PM
lol before long youll dream of doin the job in your sleep! dont worry it gets easier the more times ya do it til ya break a bolt in the motor lol
mike reeh 10-04-2003 10:18 PM
are you sure about the deck and the heads being flat? Also did you use any sealant on the steel shim gasket before you installed it? lastly what did you torque the heads to and did you ever re-torque?
just a couple of things that were on my mind.. fwiw, im not trying to point out any sort of error, just curious for my own personal knowledge
mike
Prerunner1982 10-04-2003 10:59 PM
atleast our trucks are fairly easy to pull heads on, had to pull the head on an 90+ escort.... yeah talk about PITA!
swervin ervin 10-05-2003 12:19 AM
Mike,
these gaskets have a sealant made on them, so you don't have to use any other sealant. As far as the surfaces being flat, who knows. It was on the Goodwrench 350 with very few miles. Never retorqued them either. I'm thinking the surfaces weren't straight enough for steel shims. I'm also thinking the biggest cause of failure is aluminum heads and cast iron block don't work well with these gaskets, no matter what anyone told me. For as many who said they would be fine, as many said they wouldn't. I believed the ones who said they would. It has something to do with the different heating and cooling cycles of aluminum and cast iron that causes problems. I'm getting too old to be worrying about this crap. I'm going back with composition gaskets and forget about it.
mike reeh 10-05-2003 12:47 AM
interesting. Why dont you have the heads shaved while they're off, about the difference in thickness of the steel vs. comp. gaskets? you could kill 2 bird with one stone that way..
mike
79BIG10 10-05-2003 11:08 AM
Good idea Mike R. :) Also Swervin order some ARP head studs if you haven't already. This will be more reliable as well.
swervin ervin 10-05-2003 12:50 PM
The reason I don't have them shaved is they are 64cc heads. My plan, someday, is too build a engine. I plan on flat top pistons for a CR of around 10 to 1. If I shave the heads it will mess up these plans. The GM Goodwrench 350 has some terrible dished pistons in it. That's the plan anyway.
Studs are nice, but I think I'll wait on any of this stuff when/if I build a new engine.
1FaastC10 10-05-2003 05:20 PM
IMO, you shoul install the studs before you do any damage to the threads in the block. since the shortblock isnt going to be disassembled, i'd say its safe to assume you're not going to run a thread cleaning tap though the holes. install em now for cheap insurance.
rage'nrat638 10-05-2003 06:13 PM
HOLD ON SWERVING
JUST A THOUGHT......................
when i built my rat...with alum heads....my engine guy told me to add some BARR'S STOP LEAK...TABLETS.........
to the rad. before i even start it.....
i was like what:confused:
he told me that alum. heads leak......
SO I DID IT......NO LEAKING.....
:flag:
1FaastC10 10-05-2003 06:42 PM
all GM motors from the factory use a GM version of stop leak. looks almost like sawdust tablets, you might try that and see if it stops.
swervin ervin 10-05-2003 06:45 PM
Not going to install studs. Already ordered the gaskets so it will be fixed in a week or so. Aluminum heads don't leak normally any worse than iron heads, as long as you use the right gaskets and don't try to use one not made for the application. This is what I did.
