-   The 1947 - 1959 Chevrolet & GMC Pickups Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=13)
-   -   Timing cover (https://67-72chevytrucks.com/vboard/showthread.php?t=715887)
cyclonewade 08-23-2016 09:47 PM
Timing cover
I have a oil leak in the front while my 216 is running. I suspect the seal and gaskets have gone bad on cover and pan. I'm aware of the timing cover modification for outside bolts. I don't plan on doing that as it requires pulling radiator and other items for front access.
Is it possible to remove timing cover with out pulling out radiator?
73kay 08-24-2016 02:06 AM
Re: Timing cover
I would bet on the front seal behind the balancer. I recently just took apart my 235. There are two bolts under the pan that you have to remove to get the front cover off. A big pain. I think either way the rad gonna have to get moved.
