no spark how to trouble shoot coils?
2008 5.3 engine will not start but, it does turn over and I have 80psi at the fuel rail when cranking, I checked for spark and nothing, how do I trouble shoot the coils? Should I pull the fuel rail along with the injectors to see if they are all spraying? Any help greatly appreciated.
Re: no spark how to trouble shoot coils?
Did you check the ignition fuse?
I checked all the fuses, they are good.
Take a look at the harness that branches off of each coil on to the main leg. Those wires can occasionally get pinched, pulled, or broken (usually when the valve covers needed to be accessed, the coils all get moved, and the harness gets damaged).
Do you not get spark on ANY of the leads, or just on a few? If you don't get spark on anything, its usually not the coils to blame. |
I used my old school timing light on my 2002 Toyota individual coils and it lights just a bunch of times instead of just once like the old gen 1's. I was able to locate the bad coil as it did not make any lights at all. I just clamped the plug wire clamp to the small wires going to the coils.
ok so I checked all 8 coils going to the pink wire on each one of the connectors and they are all getting 12volts but, I checked the black wire on all 8 for chassis ground and nothing. I think I missed one of the grounds on the harness but I can't find it.
My harness had 3 ground wires that are tied to the block
well well well what do we have here.....
She fired right up but, the throttle is not responding, I think it's because I'm running a 2008 Impala pedal. Also I'm getting a misfire, I'm going to check the injectors.
Swaped D and F pins on the pedal connector and that did it, I'm getting instant throttle response. I erased the p2138 code hope it don't come back.
Congratulations!
Thank you Craig.
^^^^^ wtf?????
First post too! I am sure there is a very good explanation for this................. maybe not!!!! |
Am I missing something???
Just wanted to thank everyone for your help, I got more input here than any other site, well maybe LS1TECH was helpful also, Ls1Nova would always respond to my novice questions. Took her out for the 1st time and it seems like I might have a vacuum leak, it revs really high when I'm at a stop.
