-   The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=12)
-   -   1988 C1500 CLUTCH HELP! No pressure, won't bleed. (https://67-72chevytrucks.com/vboard/showthread.php?t=717051)
PinkCareBear1986 09-06-2016 12:25 AM
Okay, so I have a clutch with no pressure. We have replaced the master cylinder, the slave cylinder, the flex line... The push rod in the slave cylinder is NOT moving and we are bleeding it by the book for both the master and slave cylinders. After we bleed the master, we move to the slave and we just aren't getting any pressure to it and the push rod is NOT moving. My Dad has been a mechanic for 40+ years and is baffled. Please help! LOL
TurnNBurn 09-24-2016 02:22 PM
Re: 1988 C1500 CLUTCH HELP! No pressure, won't bleed.
did you try vac bleeding from the slave up to the tank. then once you have something you should be able to bleed the normal way
PinkCareBear1986 09-25-2016 06:11 PM
We finally got it. Thank you for replying though.
