-   -   383 4l80e in the 6cyl mount position (https://67-72chevytrucks.com/vboard/showthread.php?t=719088)
likeenz24 10-01-2016 10:27 AM
Has anyone installed a 4l80e behind a small block in the 6 cyl mount position? I have search and can not find any info on this. The cap is off the frame getting paint and I would like to have drivetrain installed before its reinstalled.
72MARIO 10-01-2016 03:44 PM
Re: 383 4l80e in the 6cyl mount position
I have my ls engine set way back and still have room for the 4l80 and a low hump. I think you should be fine.
likeenz24 10-02-2016 03:35 PM
Thanks 72Mario for the info. Did you set you mounts close to where the 6 cyl mounts go? Do you have any pics?
special-K 10-03-2016 07:11 AM
Why not forward in V8 position and make life easier? Nice to have room to work on distributor and the O/D trans is longer anyway.
