-   Suspension (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=25)
-   -   Need help locating air ride parts/ info (https://67-72chevytrucks.com/vboard/showthread.php?t=719220)
Robznob11 10-02-2016 06:25 PM
Hey guys. I need a little info here. I I'm fixing to put dom 2600 bags on my truck stock trailing arms with lower plates. No plates on top. I'm gonna run porterbuilt arms and plates up front. I need to know what size and length bolts to install the bags. Particularly on the rear. I have seen pics of bolts with a nice aluminum washer....I just need them to be strong and engage all threads top and bottom. Also with my oil pan clearance I may not be able to air out all the way in front. Where is the best place to install a bump stop and not have it damage the bag?
bbbc10 10-02-2016 09:04 PM
Re: Need help locating air ride parts/ info
do you have inner fenders an stock crossmember?
Robznob11 10-02-2016 09:07 PM
No inner fenders, stock crossmember, relocated hood hinges...
gringoloco 10-03-2016 01:19 AM
Rear bolt: measure the trailing arm, add enough length for the washer and to engage the bag to manufacturer spec'd depth. Harmonic balancer washers work well.
Front bump stop: check out how ART mounts theirs, off of the outer bolts for the upper plate, facing down.
andrewmp6 10-03-2016 02:28 AM
Does your oil pan hang lower then then the lower control arms ?
Robznob11 10-03-2016 06:31 AM
Yes, I have made a metal cage and skid plate for protection. Eventually I will pull the motor and change the pan. But I have not wanted to go through that Hassel yet....
