-   -   Engine Stands (https://67-72chevytrucks.com/vboard/showthread.php?t=719810)
ecna 10-09-2016 11:44 PM
Engine Stands
Can someone confirm left/right engine stands for a SBC. Attached is a pic as I think it should be. Does that look correct or is it reversed and should curve forward? Thanks.
Zeroman 10-10-2016 06:51 AM
Re: Engine Stands
ecna, check out the thread about the frame pictures. There are many shots of the engine stands, probably answers your question.
http://67-72chevytrucks.com/vboard/s...d.php?t=700421
ecna 10-10-2016 11:27 PM
Re: Engine Stands
I have literally spent hours reading engine mount threads. I also just went through the link you posted. There is one kinda decent shot but not enough from above to see the angle. With all the experience in this board, I thought identifying left from right would be an easy question. Thanks for the link though.
biketopia 10-11-2016 08:33 AM
Re: Engine Stands
I can look at mine this evening and get you a pic if needed.
ecna 10-11-2016 12:40 PM
Re: Engine Stands
That would be great. Thank you.
Look at my pic, you can see the way I have it (and think it fits best) it turns towards the back of the truck. If I flip them, they turn towards the front of the truck. The holes in the frame have been welded closed as it had a different mount system installed previously, otherwise it might me much more clear. Obviously I want them correct before I drill holes.
BugzC10 10-11-2016 01:55 PM
Re: Engine Stands
They point towards the rear like you have it positioned.
67c10rustbuket 10-11-2016 10:59 PM
Re: Engine Stands
Looks correct to me. Here's mine.
ecna 10-11-2016 11:10 PM
Re: Engine Stands
Thank you!
ecna 10-11-2016 11:11 PM
Re: Engine Stands
Wow. Clean frame. Thank you!
biketopia 10-12-2016 09:06 AM
Re: Engine Stands
Looks like you got what you needed, I got home later than expected last night and it was dark by the time I got out to the yard.
ecna 10-12-2016 11:24 PM
Re: Engine Stands
No problem. I appreciate the thought.
