4.5 - 6 drop
This is not a 4.5-6 drop, is it? This is a lowering kit sold by the big Mc'. How can I achieve this drop? An air ride suspension doesn't count. Also, can this stance turn? I hate driving in a straight line.
Re: 4.5 - 6 drop
Thats not even close to a 4.5/6 drop its bagged an what is big mc? An its drivable jus raise it up a few inches
Re: 4.5 - 6 drop
I would say it is not drivable at that height. From the pics I would say the front control arms are sitting on the ground. That is how my 65 sits when aired out. You could get close to that with a static drop with one of these.http://www.nolimitengineering.com/pr...tegory=6157548
Jimmy |
Re: 4.5 - 6 drop
The big Mc is McGaughy. When you Google 4.5/6 inch lowering kit this photo comes up. I like the stance this is the loo I want for my truck.
Re: 4.5 - 6 drop
Then u have to bag it static that low is not going to happen
Re: 4.5 - 6 drop
Why would McCaughey lie to me? I thought everything on the internet was true. with a static drop, what's needed to come close? does anyone have the recipe with pics? thanks in advance , Clark
Re: 4.5 - 6 drop
2 Attachment(s)
These are not the best pics, but this long bed has a 4" front and 5" rear drop. Rides and drives nice, no rubbing...Jim
Re: 4.5 - 6 drop
I don't think you can get anywhere near close to that drop without bags or some heavy modifications.
Re: 4.5 - 6 drop
Ur not gonna get close to as said above
Re: 4.5 - 6 drop
This is what I'm working with.
Re: 4.5 - 6 drop
bag it or go with 5/7 drop cant go lower than that
Re: 4.5 - 6 drop
Thats more like an 8-10" front drop with 10-12" in the rear at least. No way its driveable with stock chassis, the crossmember will be laying on the ground. With a 5" front drop on my old 79 I've almost ripped the lower control arms off in construction once so......
Re: 4.5 - 6 drop
Like that deep dish look on the back, 20x14/15 ??? fronts, I would say 20x8 ;)
Second look could be a 22/24" rim on the back. |
Re: 4.5 - 6 drop
If you want it to sit that low you really need to bag it. Yes, you can set up a static suspension that low, but it would just be a show queen because it's not going to drive like that.
Static is cheaper to do wrong (when speaking of large changes), but much harder to do right. Since you can't adjust it; you have to carefully engineer it to maintain travel, geometry, and ride, none of which will be there if the static stance matches that picture. An air suspension lets you drop to extreme levels when siting and then air back up to a more usable ride hieght when you want to go somewhere. |
Re: 4.5 - 6 drop
