-   Welcome Area (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=50)
-   -   Transmission Conversion (https://67-72chevytrucks.com/vboard/showthread.php?t=729001)
Lowell G 01-30-2017 06:27 PM
Hello, I need some advise. 1967 Chevy C10, 250 6 Cylinder with 3 speed manual transmission. Going to put in a 383 with a 700r4 automatic transmission. What do I need for a cross member for the transmission? I don't think the current cross member for the 3 speed manual transmission will work, but could be wrong. I want to get this done while I am painting the frame. Thanks.
mongocanfly 01-30-2017 11:59 PM
Re: Transmission Conversion
You might get some responses if you post this in the 67-72 forum
396ci 02-08-2017 10:24 AM
you can use a turbo 350 cross member but the manual one wont work. i had a 350/350 in my 70 c10 and installed a 700r4 and the stock cross member worked fine, it just needed to be moved and i had to drill some new mounting holes in the frame.
not sure if you can use the 6 cyl motor mounts on the v8 install. good luck on your project!
AussieinNC 08-17-2017 06:11 PM
The current rear engine mount cross member needs to be removed totally.
The V8 will require new engine mount towers and of course, new mounts.
You will need a rear trans cross member, either from a 350/350 truck or aftermarket...
As you realize, its a lot easier to do all this while the cab is off the chassis.
:chevy::chevy::chevy:
alysaasmith 08-23-2017 09:24 AM
1967 Chevy C10, 250 6 Cylinder with 3 speed manual transmission. Going to put in a 383 with a 700r4 automatic transmission. I don't think the current cross member for the 3 speed manual transmission will work, but could be wrong. I want to get this done while I am painting the frame.
