NEW! Square Body StreetGrip
Attachment 1623421
For Immediate Release February 16, 2017 With the values of 67-72 GM C/K pickups on the rise, some enthusiasts are turning to GM’s 3rd generation or “Square-Body” pickups. In production for 15 years, “Square Body” pickups are more plentiful than prior generations. The stylish body style also lends itself nicely to customization. Today's "Square-Body" owner wants to enjoy driving their truck as much as they enjoy driving their new Camaro. You want ride quality. You want handling performance. You DO NOT want to spend weeks or thousands of dollars to accomplish this objective. RideTech feels the same way! That is why the StreetGRIP suspension system was created! Now available for the squarebody GM pickups, RideTech's new StreetGRIP system offers the following benefits: •Easy to install - direct replacement for factory suspension - no cutting, welding or other chassis modifications. One Box... One Solution! •RADICAL improvement to ride quality and handling performance. •Aggressive real-world lowered stance. •Application-calibrated RideTech HQ Series Mono-Tube shock absorbers with forged bodies and rebound adjustment. 1,000,001 mile warranty! •Application-specific coil springs and composite leaf springs offer the best of both worlds...ride quality and crisp handling. •Delrin self-lubricating control arm and leaf spring bushings eliminate unwanted movement and stiction in suspension. •Larger swaybar minimizes unwanted body roll through the corners. •Drop spindles offer a 2.5" drop for that perfect stance without sacrificing suspension travel. Check out the link below for installation photos and videos! http://www.ridetech.com/info/2017/02...9957b-92839397 |
Re: NEW! Square Body StreetGrip
Nice! I was waiting for this kit to come out. Are we able to purchase items individually?
Yes! Any of the items in the kit are available for individual purchase. Feel free to contact me directly at JJohnson@ridetech.com
Ill be more than happy to help you out. |
Old thread, but does this setup work on the suburban? I assume the front is pretty straight forward, but the frames are little different in the rear. maybe close enough though? I know ridetech doesn't play in the world of close enough, but I was curious if it had been looked at all.
I'm talking about an 85 C10 Suburban, BTW. |
The front spring rate will be fine and good to go. I would say we would have to look into alternative methods to get the rear up to the correct ride height. |
See the newly released StreetGrip kit for the 88-98 C1500 platform under that section of the forum!
