-   -   Help Me With this Wiper Delay Circuit (https://67-72chevytrucks.com/vboard/showthread.php?t=731615)
blown240 03-01-2017 03:00 PM
After searching for a wiper delay for my Panel I came across this schematic. I like to tinker with electronics, so I am going to build one and see how it works. From what I read, this should give an adjustable wiper delay from 1 to 10 seconds.
Even better, I dug around in the garage and found most of the parts I need.
Here is where you electronically inclined guys can help. I need to figure out the smallest way to lay out the components on a circuit bread board.
Here is the schematic:
http://i899.photobucket.com/albums/a...psrbcqpgsy.jpg
Built exactly like this will require a different wiper switch than stock, but it would be pretty easy to get the stock switch to turn on a relay to power this circuit...
Captainfab 03-02-2017 12:35 AM
Re: Help Me With this Wiper Delay Circuit
I can't help you with your electronics project and while I am all about building things yourself, it is hard to beat these already made wiper delays.
http://www.67-72chevytrucks.com/vboa...ht=wiper+delay
blown240 03-02-2017 02:42 PM
Thanks for the reply Capitainfab. I didn't know there was already one available. If the one I build doesn't work, I may go that way.
n8op 03-02-2017 10:01 PM
Buy one. Pull the pot/switch off the board and extend it with wires to the dash mount the rest under.
Clyde65 03-02-2017 10:50 PM
I have two of the ones sold here on the board. One is installed and works great, the other is waiting on my lazy but to install it.
PGSigns 03-03-2017 08:01 AM
I have two also and they work great. You can get spoiled quick by them.
Jimmy
corvettejim1968 03-03-2017 08:49 AM
yup bought mine off the board a couple years ago
http://img.photobucket.com/albums/v6...psmsrdbqlj.jpg
GMDad 03-03-2017 09:07 AM
Installed mine a year ago. Really like it as well
blown240 03-03-2017 05:05 PM
Thanks got the replies guys!
I got mine build, but when it didn't work, I realized that one of the transistors I bought isn't what the guy said it was, so back to Frys. The thing I really like is how tiny the circuit is.
http://i899.photobucket.com/albums/a...psolc5wvge.jpg
http://i899.photobucket.com/albums/a...ps5d4uxzjn.jpg
blown240 03-06-2017 02:52 PM
SUCCESS!! I got this working and it works very well!
Delay is adjustable from 1-1/2 seconds to 55 seconds. The pink wire goes to power, and the white wire goes to a relay to switch ground on the wiper motor.
http://i899.photobucket.com/albums/a...psjjhfojff.jpg
http://i899.photobucket.com/albums/a...psayibmqbf.jpg
Captainfab 03-07-2017 01:05 AM
That's good to hear that you got it to work.
When in delay mode, do the wiper arms always stop in the park position or do the just stop wherever?
blown240 03-07-2017 12:32 PM
Yes, the wipers park every time.
thanks!
I will try to get a video of them working later this week...
blown240 03-07-2017 08:46 PM
Here is a video of it working. It parks every time, and the delay if from basically none, to about 55 seconds...
https://youtu.be/BRVkJyZO3Ho
[video]https://youtu.be/BRVkJyZO3Ho[/video]
blown240 03-08-2017 01:42 AM
This may only work with a single speed wiper, Im not sure. The cool thing is that there is still only 1 control for wipers...
Captainfab 03-08-2017 01:47 AM
Looks like it works good. Did you replace the original wiper switch with the delay pot?
blown240 03-08-2017 01:50 AM
Yup, Replaced original switch.
Thanks!!!
Its a real good feeling making something that worked out so great!
mafosa 03-08-2017 08:20 AM
thats cool! you going to share the parts list?
larry
blown240 03-08-2017 12:39 PM
Thanks mafosa!
t300 03-12-2017 01:42 AM
Thanks!!!
Thats cool, nice work!
