-   The 1967-1972 Chevrolet & GMC Pickups Parts Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=8)
-   -   CA OEM air cleaner, heat stove, pipe, carb spacer (https://67-72chevytrucks.com/vboard/showthread.php?t=734086)
leddzepp 03-29-2017 07:48 PM
Everything pictured. $140 shipped USA. This setup is for a small block.
Eagle9502 03-29-2017 09:47 PM
Re: OEM air cleaner, heat stove, pipe, carb spacer
I'd be interested in the heat stove parts if you decide to separate.
leddzepp 03-29-2017 10:10 PM
Which specific parts? I have others as well.
71deluxe 03-30-2017 12:29 AM
I'm also interested in the heat stove parts only. Specifically the riser pipe and the outside manifold piece, if you still have more of those available. Pics please. Thx.
JackB 03-30-2017 02:39 AM
I'll take the whole lot..
leddzepp 03-30-2017 10:35 AM
All yours. I'll pm payment info.
leddzepp 03-30-2017 10:39 AM
I'll pull out what I've got and post pics this evening when I get home from work.
cjmorr13 03-30-2017 10:57 AM
Do you have another hose for pcv to spacer with clamps? IIR would you part with the one in the pic seperatley?
leddzepp 03-30-2017 11:16 AM
I'm pretty sure I do. I will post pics later tonight.
seattle gmc 03-30-2017 12:28 PM
I will take the whole set if you don't want to separate them.
leddzepp 03-30-2017 12:37 PM
You are second for the whole setup, see post 5 above. Thank you.
Eagle9502 03-30-2017 03:54 PM
I'm interested in the heat stove pipe and exhaust manifold shields.
leddzepp 03-31-2017 01:04 AM
I ended up having another setup, same parts as above, same price. Here is a pic.
The only extra part I have is a heat tube shown at the bottom in the pic. $45 shipped. Eagle9502 let me know if you'd like it.
Eagle9502 03-31-2017 07:54 AM
I'll pass and keep looking for the tube and manifold shields together. I have everything else. Thanks
71deluxe 03-31-2017 11:27 AM
How much for the tube shipped to 98230?
leddzepp 03-31-2017 11:53 AM
$45 shipped anywhere in the USA. I use a flat rate usps box.
cjmorr13 03-31-2017 03:35 PM
Did you find an extra pcv tube assembly?
71deluxe 03-31-2017 04:16 PM
Thanks I'll pass on the heat tube.
leddzepp 04-01-2017 08:53 PM
I did not. Seattle gmc has purchased the second setup, minus the shield and a tube.
leddzepp 04-01-2017 08:55 PM
Seattle gmc purchased the second setup, minus these three pieces. $75 shipped for them if you are still interested, thanks.
jocko 04-01-2017 08:59 PM
I'll take those three scott, thanks - pm sent
EDIT: OOps! Sorry about that - please put me in line if Eagle9502 passes, thanks!
Eagle9502 04-02-2017 10:01 PM
Any deep rust holes or pitting in the tube or manifold pieces? If not, I'll take it.
leddzepp 04-02-2017 11:58 PM
All pieces are solid, surface rust on exterior heat shield. Pm sent
seattle gmc 04-12-2017 11:32 PM
Scott-
I got your fedex today, thank you. Nice job on the packaging. They could use you at the UPS store.
