Rear brake line on the 64 GMC
Is there a Napa number for rear flexible brake lines for a 64 GMC? I was going to take mine in and see if they can match them up or use the fittings to make up a new set.
Re: Rear brake line on the 64 GMC
What model truck? I have an old Napa catalog. I can look it up tomorrow when I get to the shop.
George |
It's a 3/4 ton 1500. That would be great, thanks.
Rear brake hose part # is 33676 Napa. It is 17 1/2 in. long. 7/16"-20 male on one end & 7/16-24 on female end. In case they didn't have this one, or your truck sits higher then normal, part # 36563 has the same specks & is 18 3/8in. long.
George |
Thanks a lot for the info. I'm going to go there tomorrow with the numbers and the specs and see what they can do. I'm in British Columbia, but the truck was originally sold in Kansas, from a place caller White Mach. & Motor Co., in Goodland Kansas.
