Brake booster
anybody using an s10 brake booster and master on a 62 using Capt. Fabs bracket with clutch setup. How does it work for you. Goods, bads. Thanks.
Re: Brake booster
Are you having problems with the brake booster?
Re: Brake booster
Re: Brake booster
Re: Brake booster
Re: Brake booster
5 Attachment(s)
Then I decided I wanted more adjustability so I bought a brake bias valve from Summit that allows me to reduce the rear drums down as low as 52% or anywhere above that. The brake bias valve is badged as "Summit" but underneath the badge it has Wilwood cast into the metal. So it's really a Wilwood product. I cut the ring off the Blazer booster push rod and tapped it. Then used a Speedway pushrod extension with HEIM joint. I drilled a new hole on the pedal arm for the pushrod to bolt on. That reduces the pedal sensitivity a bit. |
Re: Brake booster
Re: Brake booster
3 Attachment(s)
Speedway Motors Pushrod Extension LINK |
Re: Brake booster
Lugnutz.... Nice write up! What die did you use for the threads, is that the 3/8"-24 they have listed on speedway website?
Also the hole in the brake pedal arm is that 1" below and why is that even needed? |
Re: Brake booster
Moving the pushrod down 1" decreases the mechanical leverage so the brakes are less "touchy". I read an article on the subject and I'll try to find it. Basically, drum/drum brake systems usually have a pedal leverage of 8:1. Moving the push rod down reduces the mechanical leverage to somewhere closer to 5:1. |
Re: Brake booster
Would that be the same and as beneficial for disc/disc?
Re: Brake booster
Yes. Moving the pushrod down 1" is for both disc/disc and disc/drum applications.
Re: Brake booster
Here is the NAPA article about brake pedal ratio I referenced above. LINK HERE.
| All times are GMT -4. The time now is 01:05 AM. |
