-   -   Updating Grille emblem (https://67-72chevytrucks.com/vboard/showthread.php?t=741904)
Bennydog 07-07-2017 03:37 PM
4 Attachment(s)
Hello, I recently got a 75 SWB C-10 and have been doing some small things to it. It had the repop grill from a 78 on it that had the hood latch in the wrong spot. I got super lucky and found a correct 75 grille along with (3) 73-34 grilles and a correct 77-79 grille with the strips... I bought all 5 because why not??? Anyway the 75 grille had the 350 emblem still there but no Bowtie, i found the bowtie at the junkyard for 5 bucks, needs the yellow center replaced or painted but the chrome was good, I will work on that later. Grille has been cleaned and sanded and de-greased and has primer on it now. Going to paint today. I will update this when it is complete. Anyhow I did the 350 emblem using a engine black for the background carefully taping off the numbers, and then did the testors paint mix flat yellow and flat brown i learned from the square body syndicate. Here are some pics.
Bandit130 07-07-2017 05:39 PM
Re: Updating Grille emblem
This is the thread of my emblem painting and the color formula.
http://67-72chevytrucks.com/vboard/s...d.php?t=735763
TKCR 07-07-2017 09:24 PM
That is tedious work right there, nice job!!
Bennydog 07-08-2017 05:38 PM
5 Attachment(s)
Well, I did the bowtie and got the grille painted. I would rather have the correct insert with the lines in it but i will settle for this one i painted until i can locate the correct one.. Well here she goes.
TKCR 07-08-2017 08:37 PM
That looks AWESOME!!! You did a great job
Nuckingfuts 07-09-2017 02:30 PM
Good work!!:metal:
I need to do something similar to my fender badges.
gmachinz 07-09-2017 10:42 PM
Looks good!
