-   Heavy Haulers (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=239)
-   -   C50 Rear Brake Help (https://67-72chevytrucks.com/vboard/showthread.php?t=746146)
split 09-06-2017 08:41 PM
C50 Rear Brake Help
4 Attachment(s)
The rear end in this C50 is not original. It seems to have a heavy duty 15K lbs or 17K lbs dual speed axle...year unknown.
I'm replacing the wheel cylinders. The problem is that the brakes don't seem to match any shown in any of the 67-72 manuals.
It may be that there is simply missing parts courtesy of the previous owner.
Take a look and see if you can ID these brakes.
The Star adjusters which adjusts the brakes have no mechanism to kick them tight.
The upper and lower halves are mirror images of each other. The top has an unusual spring clip around the star adjuster threads. No matching clip on the bottom.
In the last picture is a strange piece that does not seem to do anything. Perhaps pointing to missing parts which attached to it. If there are missing parts, I'm probably screwed as I doubt I would find anything for this old thing
split 09-06-2017 08:49 PM
Re: C50 Rear Brake Help
I believe this is a pretty good match.
This is from the 1967 shop manual.
It does appear that I'm missing:
Actuating Lever
Return Spring
Over ride spring
Over ride Lever
Anyone know where I can find some replacements?
Dannny B 09-06-2017 10:00 PM
Carlson seems to have all the hardware kits. This one looks about right.
Got an error message.
eBay item number:
272132484846
Details about Carlson H3510 Drum Brake Self Adjuster Repair Kit
split 09-06-2017 10:28 PM
I do see a difference between the Manual photo and my setup. The bracket with the two large bolts that supports the star wheel, looks like a stamped piece of steel in the picture, where as mine is a thick cast piece. But maybe is just because the manual picture is so perfect and mine is a rust mess.
What is the acutal model of this rear end? If I knew, I can search ebay.
Also, the kits on ebay are listed as left or right.....but I don't see any parts in the picture which are just for left or right. What am I missing?
Dannny B 09-06-2017 10:42 PM
Carlson lists a lot of kits. I'm pretty sure that you can find just what you need.
http://www.carlsonqualitybrakeparts.com/catalog
split 09-07-2017 09:55 AM
Carlson has no listing for a ~70 C50. I have emailed them.
FYI, the H3510 is the left, and the H3511 is the right. But from what I can tell, these are for 1979 and later.
Dannny B 09-07-2017 11:09 AM
I have those same brakes on my C-50. I believe that the actuating lever is the right-left difference. Apparently, your automatic adjusters have been removed. If you aren't heavy and don't get a lot of miles, it isn't such a big deal. You can just manually adjust. The little cam is used for "calibrating" the adjuster during assembly. You turn the cam until the adjusting lever sits just right against the star wheel.
split 09-07-2017 12:16 PM
Response from Carlson:
We currently have the H3510(left side) & H3511I(right side) adjuster kits
Yes this fits a 1967-72 Chevy C50 Rear with 15” x 4” Drum Brakes.
Chad Warnecke
Global R&D, Engineering and Quality Engineer
International Brake Industries
1840 McCullough
Lima, OH 45801
419-993-8162
