-   The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=38)
-   -   Drive shaft question (https://67-72chevytrucks.com/vboard/showthread.php?t=746515)
barnold 09-12-2017 09:59 PM
I and installing a 5.3/6L80e combo. What is everyone doing for the drive shaft. Staying 2 piece or converting to single?
nastety92 09-13-2017 08:19 AM
Re: Drive shaft question
We are putting a 5.3 and 4L60E in my 67 Suburban and staying with a two piece. I've read that people have had their stock shaft modified.
LockDoc 09-13-2017 11:48 AM
I would stick with a 2 piece on a Suburban.
You might try a 350/350 two piece shaft. I put an LS1/4l60e combo in my Panel Truck and that shaft fit with no modifications. I don't remember off the top of my head if it was the long one or short one. If I get a chance today I will measure it.....
LockDoc
barnold 09-13-2017 10:58 PM
Thanks for the info
LuckyScott 09-13-2017 11:02 PM
Inland Empire sells a two piece shaft that slides in and out so that when you lower the suburban in does not bind. I have one in my truck and it works great. They also use the heavy duty aftermarket poly center bearing support.
nastety92 09-14-2017 08:39 AM
Scott do you remember how much you paid for your two piece shaft with the carrier bearing?
Thanks,
Nick
LuckyScott 09-14-2017 03:29 PM
No, its been too many years. call them up and they will let you know how much it is.
