k-30 ds tank mount - pics ??
im installing a new cab on my 83 k-30 -when i got it the drivers side tank & mounts was off & in the back {it is a cab & chassis w-a masons bed on it }does anybody have some pics of there truck & the mounts ? i got several from a junk yard ! just need an idea on what i need & which one goes where ?? thanks
Re: k-30 ds tank mount - pics ??
are you talking about tank supports or the crash cage? about half the tank is under the cab..I can get picks tomorrow of mine but its a 81..
probably both ?? i got a new tank & blasted some of the other supports & cage -just need to get an idea of what goes where ?? thanks guy !!
i got the front tank support figured out -just need to redrill 2 holes ! the rear mount is taller - somehow it must fit with a cage ?? around it ?? plus it has a tall fuel fill neck-above the rear mount ?? any pics would be great ?? thanks mike
found this..
5 Attachment(s)
maybe thisll help..if you need a specific pic let me know and I'll see what I can do
thanks !!!! THAT CAGE IS WHAT MINE HAD - AT 1 TIME !now just need to find some more brackets ?? thanks mike
