-   -   BB oil pan indentations - need info. (https://67-72chevytrucks.com/vboard/showthread.php?t=747015)
CCCC 09-21-2017 12:47 PM
This post/question might be more relevant in the engine/drive train section but there seems to be more such traffic here and I need info quickly.
Am finishing a trans/clutch, new rear main seal and oil pump check on a 402 BB and am cleaning the oil pan before paint/install. I have never removed/inspected a BB pan before, so am uninformed. This one has some indentations and I don't know which ones may be factory design and which are PO dents that should be banged out.
Does the normal BB pan have an indent (about 3") immediately next to the drain plug (on bottom of pan toward the center and running lengthwise) and is the shallower part of the pan supposed to have a small oblong indent crosswise - and past it a small round indent - both centered on the midline?
Thanks for any quick insight.
Doug's68SS 09-21-2017 12:52 PM
Re: BB oil pan indentations - need info.
pictures would make it easier to help you out.
CCCC 09-21-2017 03:14 PM
Doug*** Thanks, I thought about that - need to get it completely clean first and will try to post a pic if that becomes necessary.
weq92f 09-21-2017 04:58 PM
Stock Pan image. Does this help?
weq92f 09-21-2017 05:00 PM
Another angle
Ironangel 09-21-2017 05:53 PM
That indent is for the oil filter clearance...
CCCC 09-21-2017 08:58 PM
Thanks a bunch weg921 - that is perfect. Your pic shows that the minor ones I already have removed were needed, and now I need to bang out the dent just adjacent to the drain hole. It is a rather sharp crease and not easy to get to due to an existing baffle, but think I can get some of it, at least. Thanks again for the quick help.
CCCC 09-22-2017 11:53 AM
Actually, the specific configuration of the bottom side of those two pictured BB pans is different - neither bottom is shaped exactly like mine (which I believe to be OE) - but both have the same important aspects showing that I need to press out one sharp dent. Thanks again.
weq92f 09-22-2017 12:05 PM
Sweet, sometimes close enough works!
-klb
