-   -   1960 C10 Mystery "Blue hole" (https://67-72chevytrucks.com/vboard/showthread.php?t=748941)
Submariner616 10-22-2017 12:42 AM
2 Attachment(s)
On my 1960 C10 283 with 2 speed powerglide that I am restoring, there is a hole in the firewall next to the master cylinder with a light blue plastic "pipe" through it. Inner diameter is 1 and 13/16th inches, outer diameter is 2 inches. Please see photos.
Does anyone know what this is? Is there a plug that is supposed to go in there?
62stepside longbox 10-22-2017 04:40 AM
Re: 1960 C10 Mystery "Blue hole"
Looks to me like the hole for a 60-62 clutch master cylinder, if the truck was a manual transmission then I would've been equipped with a different master cylinder, for both the brakes and the clutch. I'm guessing someone swapped to an auto tranny.
62stepside longbox 10-22-2017 04:41 AM
Like this
62stepside longbox 10-22-2017 04:44 AM
Factory auto truck would've had a plug like this
ImpalaJim 10-22-2017 07:27 AM
that backwards bow tie is killing me!
Submariner616 10-22-2017 12:56 PM
Although I have never seen one, I was kinda thinking the same thing. However, there is no other indication that it originally had a standard. If someone changed it to an automatic, they did a very thorough job. And the 2 speed powerglide is the proper one, cast iron with no pan.
Does anyone know if there is some way to determine what it was originally built with, other than the "Blue hole"?
Submariner616 10-22-2017 12:58 PM
I know, ImpalaJim, it won't be there long!!
Submariner616 10-22-2017 12:59 PM
Awesome picture! I wonder if that plug is available somewhere. I haven't seen it in all my online travels through parts websites.
ImpalaJim 10-22-2017 05:05 PM
try some ceramic shops! I bet a bank stop would work.
LVPhotos 10-22-2017 09:36 PM
The manual two port was not new to our trucks. My 56 Willeys Jeep had one, had to get new one and part # match to 62
Submariner616 10-22-2017 11:24 PM
This is the first time I have come across it, but I'm new at this. I wonder if the plug came out and someone plugged it with a piece of pipe and a cap.
