-   The 1967-1972 Chevrolet & GMC Pickups Parts Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=8)
-   -   SC Complete rear drum setup with e brake cable, 5x5 rotors. (https://67-72chevytrucks.com/vboard/showthread.php?t=749078)
PaPaStewySnipes 10-23-2017 08:45 PM
5 Attachment(s)
Installed rear wilwood disk and removed my drum setup. All functional, worked fine a month ago before conversion. Finned drums, ebrake cable, all drum components. Came off my 5 lug 72 c10. Still have stock original front disk 5x5 rotors for sell also, even have factory cooling groove and are in good shape. Drum back plate does not have much rust, it is dried clay and dirt from the back roads on property, brake line port is not stripped either. Simply soak and it will clean up good.
