-   -   60-66 Headers (https://67-72chevytrucks.com/vboard/showthread.php?t=751085)
62 short step 11-23-2017 11:47 AM
60-66 Headers
4 Attachment(s)
I know there are tons of threads on this, but the Hedman 69230's fit like a glove. Especially for a lowered truck. They are a 67-87 4x4 header but I swear they were meant for lowered trucks.
I blasted them and used POR-15 High temp alum paint. Turned out nice.
Here are a few pics of them on my 65.
DPowers 11-23-2017 11:58 AM
Re: 60-66 Headers
Very nice.
The Rocknrod 11-23-2017 12:07 PM
Re: 60-66 Headers
Nice. Are you using a fan on that engine with the shroud?
62 short step 11-23-2017 12:17 PM
Re: 60-66 Headers
Yes I am. It's a mechanical fan. I can find the part number if you need it.
Brad54 11-25-2017 05:32 PM
Re: 60-66 Headers
Those DO look like they were made for it!
Rich 5150 69 11-27-2017 12:28 PM
Re: 60-66 Headers
Looking at yours, you are running an automatic, do you think it would clear clutch linkage and Z bar on a manual...? just curious.
rvrfoot 11-27-2017 12:54 PM
Re: 60-66 Headers
I think block huggers will work also. I just installed some on a 1961 impala.
62 short step 11-27-2017 08:16 PM
Re: 60-66 Headers
No, I don't believe the z bar will clear.
62 short step 11-27-2017 08:18 PM
Re: 60-66 Headers
I had tried block huggers years ago and they wouldn't work. The ones I had anyways.
rvrfoot 11-27-2017 08:21 PM
Re: 60-66 Headers
May i ask what was the problem with them?
62 short step 11-27-2017 08:51 PM
Re: 60-66 Headers
The #1 primary tube hit the motor mount where it bolts to the top of the frame.
rvrfoot 11-27-2017 09:03 PM
Re: 60-66 Headers
Oh ok, i just put a set on a 1961 impala. Its close but not hitting.
Captainfab 11-28-2017 12:56 AM
Re: 60-66 Headers
Those headers will not work with the stock bellhousing crossmember in place. You would have to install a rear trans mount and likely convert to a hydraulic clutch.
Rich 5150 69 11-28-2017 09:25 AM
Re: 60-66 Headers
Thanks guys, just putting it into my notes...Im running an auto anyways...!
