1960 Door latch...aftermarket or?
My door latch on the drivers side has never worked correctly. It locks but will not open the door from the inside. Just wondering if anyone has had exp with the aftermarket ones? Just hate to buy a used one and have the same issue..
1960 Short fleet... Thanks |
Re: 1960 Door latch...aftermarket or?
3 Attachment(s)
Yep i got some after market ones. No problem.Attachment 1711858
Attachment 1711857 Attachment 1711856 |
Thats funny some other guy said it looks like a 60's gauge cluster.
Oh and the wife was not happy when she seen it.
Pulled it apart.. It appears just a bend was the problem, I bent it back and it works correctly although obviously the metal is fatigued so it will probably happen again. Possibly need to replace but hate to replace things with Chinesium.
I will see what kind of shape my old ones are this weekend.
Just some assembly idiosyncrasies and interchangeability with the aftermarket parts from my experience. My truck also had worn out door controls. I also went with aftermarket controls, but I had to also get new latches, and new inner door handles as my OE handle no longer fit the splines. It would've been better if I had purchased the new door controls, latches, and inner handles at one time to save on the shipping from placing three separate orders.
The aftermarket parts probably will not withstand the same amount of abuse over time, but seem to work well enough. |
It's usually an adjustment or tweaked linkage problem
Car and truck shop Orange California I'll check this weekend for the manufacturer
If I remember right...you have the door handle relay's switched rt/lt sides. The rod should be diagonal thru the access opening opposite of what you would think...I'm searching my build pictures but I did the same thing...You should be pushing on the latch instead of pulling
Wrong year but see the angle of the relay rod is on top Attachment 1712491
| All times are GMT -4. The time now is 01:05 AM. |
